Discuss MDPE fitted to garden tap - help in the USA area at PlumbersForums.net
I am trying to fit MDPE 20mm pipe to a threaded garden tap for the water source for garden irrigation, it always leaks from the MDPE fitting - i have tried various adaptors, what am i doing wrong? thank you
https://www.NoLinkingToThis/p/floplast-female-pipe-adaptor-20mm-x/32438
Should secrew on to the bib tap. You need an insert for the mdpe.
Reply to MDPE fitted to garden tap - help in the USA area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
