Discuss MDPE Pipe to 22mm in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all
So I am replacing a lead pipe in my property, and advise from another member was to replace the stopcock etc to 22mm instead of 15mm.
I was looking at the pipe coming from the road and it is a blue pipe, which was put in around 2 year ago. I presume this means it is MDPE?
Would the fitting at this link be substantial to join this to a 22mm pipe?
Many thanks in advance,
Aslong as you have a 25 mm blue alk pipe your trying to join onto
I just found the MDPE stoptap (25 x 22). That is a better option for me. When you say liners? Are those the pushfit pipe nserts?
Yes and the white 25mm alk liners
If you do use speedfit and compression don’t use the super seal inserts
Supers are great for push fit fittings but there too big for compression
You need the regular jg inserts for compression
Reply to MDPE Pipe to 22mm in the Plumbing Jobs | The Job-board area at PlumbersForums.net
