Discuss Microbore pipe showing above radiator!! in the DIY Plumbing Forum area at PlumbersForums.net
Newish house with radiators that have microbore pipe but on one of them the pipe is sticking up above the radiator which looks unsightly. Is it possible to push the excess pipe back into the wall? I'm worried about causing a leak.
Do you have a picture of said hole and pipe ?
Here's a couple of photos
Best log it as a defect with the site maintenance as it’s new build
The house is 6 years old and the site is finished so builders have long gone. It wasn't a problem until recently but looks awful. Will try and carefully push some of the pipe back into the hole in the wall and see what happens
You won’t push it back into the wall unless it’s a stud wall
Why was it ok until recently?
It was OK when we moved in about a year ago but has slowly risen above the top of the radiator. Suspect it was crammed in when It was fitted and has slowly 'relaxed' and appeared above the radiator. I'll get a plumber to have a look and see what they recommend.
Need to be shortened I suspect
Reply to Microbore pipe showing above radiator!! in the DIY Plumbing Forum area at PlumbersForums.net
I have recently bought my own house and decided to redo the kitchen. There was a radiator in the room already but I wanted to move it. I extended...
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that...
Hi everyone. I'm currently working on a job for a customer. their radiators are not all heating up. in total there is 12 radiators. 4 of these are...
The system is about 20 years old and has never been cleaned. The radiator water looks like tar and several radiators are warm at top and cold at...
The soil pipe from my bathroom passes through the outside wall and into the roofspace above the adjacent single storey kitchen before dropping...
