Discuss Mini pipe bender in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bennythedip
Just wondering if anyone can recommend a decent mini pipe bender for mostly 10mm pipe. I have a nasty cheap one that just mangles the pipe as much as bends it! I would rather spend a bit and get a decent one as I've started doing a lot of hob installs recently. Thanks for any help.
Look for the Rothenberger ratchet one on eBay. You can get them brand new, but they are expensive.
They do last though, had mine for at least 18 years.
ROTHENBERGER MINI PIPE BENDER - 6 , 8 AND 10 MM TUBE BENDER NOT RIDGID REMS
Reply to Mini pipe bender in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the...
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
Hi All I'm planning on replacing a couple of rads soon as they are far too small for the size of the room causing the room to take an age to heat...
Hi Some people (not plumbers) have advised me that it's not such a good idea to a) Have 4 x 90deg bends in a sewer pipe and b) Encase these pipes...
1K
Hi - I'm not an expert but wondered if anyone might be able to assist. I've replaced an old toilet with a new one. I've used the same water inlet...
2K
