Discuss mira event xs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dwelling69
Good evening, I have a mira event xs and it has started to make a loud noise with only a dripple when set on warm/hot tempature -- when you turn the temp dial down to below 5 it works fine -- please can anyone help me to fix this thank you
It sounds like it may be starved of hot water. Are the feeds being pumped to the shower? If so, it may be the pump that is faulty.
If not, it may be the cartridge needs replacing, have a look at showerdoctor.
Mira event is an all in one power shower.
I'd look at the inlet filters and see if they are blocked.
Reply to mira event xs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
