Discuss Mira PPT3 HELP in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
goldcol
Hi Guys,
I have a Mira PPT3, which pumps to showers in the house. I want to disconnect one of the showers, do i just turn water off, disconnect pipes and then put some type of blanking cap over the outlets not being used, what size and type should i get.
i should think they will be 15mm. you can get pushfit stopcaps which will fit on the pipes. yes just turn wateer off.
Treat yourself to a 15mm pipeslice as well, if the pipes are copper.
Reply to Mira PPT3 HELP in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
