Discuss Mono block flexi tails in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Do people tend to just screw thi s in hand tight. I no a lot of instructions say this. I do tend to like giving a tiny nip up after if they is space to get a spanner in.
Yes if it's a recessed connection but if I can get a spanner on it I give it a 1/4 of a nip up
If unsure or cheap tap and don't like the feel of the flexi tight normally whip it out and o ring off and use some 577 on the threads
Being an o-ring it seals by its position, being trapped in the groove and within the female tapping on the tap body, not by how tight they are done up like with a washer or compression fitting.
As long as the flexi cannot unscrew, which it can't because it is fixed firmly at the other end, hand tight is as good a seal as doing it up with tools.
That 'wee nip with a spanner' after years of hot and cold could mean it needs destroying to get off at a later date. Completely unnecessary in my opinion. As above, the o-ring makes the seal. Hand tight only for me every time.
Reply to Mono block flexi tails in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
