Discuss Monobloc kitchen mixer 32mm back nut - spanner in the USA area at PlumbersForums.net
Anyone coming across these tap fixing components. I'm struggling to find a box spanner to fit. The nut is about 33-34 mm between flats. New install and as far as I can see nothing apart from a box spanner will tighten this. Unless you have the opportunity fit before installing sink.
Deep socket
Adjustable Basin Wrench
Don't think so, not enough room anyway. I did eventually find a 34mm/40mm box. I wasn't sure the sockets would be deep enough. They are pricey also. Thanks for the suggestions. Waste of time as the tap is sh......te a cheap Flexi pull down mixer. I've no doubt it will be replaced before long -
they are crap to fit, and crap tap, if its same as one i fit you have to put in place then push tails up to connect tap on,
Reply to Monobloc kitchen mixer 32mm back nut - spanner in the USA area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
