Discuss Motorized Valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Plumbers _plum
Evening all!
Does anybody know how many motorized valves are needed for a sealed system?
At least 2 on all new systems or if changing cylinder, at least 1 on existing systems
7 radiators, 1 towel rail radiator, glow worm system boiler, mega flow...................2 motorized valves enough? 2port?
Reply to Motorized Valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Morning, Does anybody know what happens to a solar thermal flat panels (a pair on south facing slate roof) that have been unused for at least 12...
I'm looking for some advice on a frustrating problem I'm having with my old Eurostar 50-60s oil boiler please? Although it's old, most parts...
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the...
Hi All, I need to replace a radiator in the kitchen, the 10mm copper has split so using this opertunaty to replace it with a towel one and also...
My daughter's place has a small water leak on a ground floor radiator valve. The radiator pipework is small diameter.i.e 8 or 10 mm. A plumber...
