Discuss Move a radiator to new location in the Central Heating Forum area at PlumbersForums.net
Hi, I want to shift a radiator about 30 cm sideways to fit a new library and wanted some advice on how to do this.
This is what I think I should do but any advice on how to do this or what products to use would be most welcome!
  • Turn off boiler and drain system
  • Remove radiator
  • Cut down intake and return pipes to radiator
  • Fit in compression elbows and extend pipework to new radiator location with new cut pipework
  • Fix radiator to new location, attach pipework and refill system.
One of my questions was whether adding new elbows would in any way impact the pressure or somehow make the system work worse?
Thank you! :)
Sorry, no idea as I'm doing it for a friend and don't really know his set-up...
Would this work for the elbows? I think the pipes there are 15mm, painted. I'd sand down the paint before installing these and use a pipe cutter to turn and extend sideways...
Reply to Move a radiator to new location in the Central Heating Forum area at PlumbersForums.net
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
My daughter bought her first home and was hoping to convert to gas but its not available in the area, so thinking a boiler upgrade is the better...
I have recently bought my own house and decided to redo the kitchen. There was a radiator in the room already but I wanted to move it. I extended...
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs...
