Discuss Multi meters-how much to spend for fault finding? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Going on a baxi course soon and will be learning how to correctly use multi meter.
Dont mind spending if I have to but do I have to spend £60-70 on one or will a cheap £20 one do the trick. I had one in the shed but think the rain got to it..it all looks ok but think it might need calibration. Is this easily done?
Get a cheap couple first as you'll probably blow them up.
Have a search on here, been a couple of threads about this.
Ive had a digital maester one that cost about £30 odd quid for years does everything i need for fault finding etc.
got a wickes special with nice big writing £19, and then bought another when first went wrong giving 440v readings on a gas valve!!
but then I changed the battery on the first and it started working correctly again:) now any issues and I get the other one out to make sure. remember tho always have some spare batteries, doh
Try to get one with temp diff on to measure flow and return:yesnod:
I don't use mine for fault finding on boilers, but for ordinary use, its worth paying a couple of quid for a continuity buzzer. Sometimes saves you going cross-eyed.
mylocalplumber, can you please give me some feedback on the baxi course as im considering going on a few soon
Cheers Pal
Thanks for all responses. Had a eureka moment when I realised I'd seen a multi meter in the shed left by previous owner. Is a Rish Multi 16s so not sure if any good but it's working..has TRMS which I've heard is good. Will leave feedback regarding baxi course.
I went on a baxi day the other week, the trainer stressed to me splashing out on a good multimeter. He recommended a Fluke to me as it lasts for years.
Reply to Multi meters-how much to spend for fault finding? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
1K
H
HRP123
H
I don't work now due to being ancient. I looked at a 'Range cooker' fired on kero. It had a slow leak that turned into a bad leak in a month! It...
2K
Hello All and thanks Lou i did write a reply but it would not let me send it? i am not sure what I am meant to write and I do not want to come...
Not sure if this is a success or a fail or just a rant but We do have heat and hot water now So all started the evening of Friday the 12th (Nov)...
2K
