Discuss Naughty Naughty Naughty in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
This is a 1st for me. Usually flexi's connecting a hob.
Called to a smell of gas...
Normally cut the upstand off and use a flat face washer
It's track pipe so that is fine. It is the compression fitting onto a flat faces washer fitting.
You Can file the threads flat though
dont see many bent tap connectors, cost more than a st elbow and nut and olive.
did it have the barrier between the top draw and hob underside? the number of kitchen fitters that hate me when i insist on the barrier being fitted is getting quite high.
Can't say I have ever seen a barrier fitted, didn't know there was such a thing
Reply to Naughty Naughty Naughty in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
is it feasible to connect a flo force or saniflo shower pump drain to a washing machine standpipe
