Discuss Navien and Worcester Oil Boilers in the USA area at PlumbersForums.net
Hi all
My sister is in the process of getting quotes for the installation of an oil central heating system (rural Cornwall) in an old house where none currently exists. For obvious reasons she is having trouble getting anyone out to quote at the moment apart from one local contractor. He has provided a quote and has recommended a Navien oil boiler which is a brand I haven't come across before. My advice to her was to go for a Worcester as this is generally recognised as one of the best brands. The guy mentioned that there have been problems with the 'intelligent system' on Worcester oil boilers which go faulty (gas are ok apparently) and also issues with the PCB. Would appreciate views on Navien oil boilers and any knowledge of the two issues mentioned around Worcester oil boilers.
Many thanks.
Peter
Navien are good boilers from what I've read (never worked on one and I don't install). Their two stage burner design offer high and low fire rates with suitable control systems to match.
Worcester oil boilers take a lot of their components from their gas cousins, as you mentioned above often comes with problems on their PCB and wiring.
Worcester used to be one of the best brands. Wouldn't go near them for a new install.
No experience with the Navien boilers.
My preference would be a Hounsfield heat only boiler and an unvented hot water system, subject to water pressures and flow.
Reply to Navien and Worcester Oil Boilers in the USA area at PlumbersForums.net
W
My Worcester Combi Boiler is not working, instead the display flashes on and off repeatedly, as shown in <a href=" View...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
I would like some guidance regarding the Worcester CDi 29 Classic boiler. According to the manual it has a holiday mode and frost protection mode...
Hey guys in the know. I have paid for a heating and plumbing contract and had to pay my excess 3 times for the same thing still not fixed. The...
Hi - I have been given 2 options of boiler to fit in my small flat, a Worcester 2000 combi or a Worcester 28 compact. The W 2000 is £150 cheaper...
1K
