- Messages
- 34,374
- Solutions
- 2
Tbh next step is to remove the rad and check you have flow from each valve etc
Discuss Need Advice about Boiler and Central Heating Repair Please in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Okay. I'll be paying a different plumber to do that then.Tbh next step is to remove the rad and check you have flow from each valve etc
It’s 10mm but it’s fine most new builds are small pipes than 10mm copper eg 10mm plastic which is around 6-7mm dia
Ideally 15mm all the way but it’s an existing heating system that was working
The rad with TRV which I have turned on now has a warm pipe under the TRV. Is this good news?It’s 10mm but it’s fine most new builds are small pipes than 10mm copper eg 10mm plastic which is around 6-7mm dia
I've been out for a few hours and returned to find the rad without TRV which I left on now has a warm pipe under where the TRV should be and the rad with a TRV which is on is actually luke warm. This looks like progress. Shall I just leave things as they are for a while?Yes very good keep it going / leave it as is try bleeding the rad to see if there’s any air there etc
Will do. ThanksJust as a helpful tip more than anything, if you have a magnet, try it on the pipes that are supposed to be blocked
Reply to Need Advice about Boiler and Central Heating Repair Please in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
