Discuss Need help bleeding system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ok well I have a Vieasman vitrodren 100 system that has 2 circulation pumps, and the one pump is making a humming noise but is working fine. I have hot water heating baseboards in the rooms and this has been working for 6 years. I just wanna bleed the system of all the gunk before the heating season starts and move the stale water. At the same time I wanna change the pump. I see all those hose bibs but can remember the sequence
have you got venting / flushing points? eg
Here is some pics of my setup
You can put it into bleeding mode and it should run the pumps and you can bleed/replace while it’s doing it. Search for a service manual would be your best bet as I doubt many people are that familiar with the system hth
No that is not a option with that system as I had the tech install hose bins for bleeding
Looks easy for three circuits
Any chance of a better pic of the circuits to the left of the boiler
Blue headed valves are your purge point so hose pipe onto that outside
Close the red lever valves after them
Turn power off to the system etc
Manually open the zone valves (note if you didn’t turn the power off the pump would run)
Open the blue head valve you should start to hear water flowing also you should hear the auto fill start to open eg letting water in etc
Give it a good 10 mins or until clean then turn the blue headed valve off
If you have gycol in the system best option would be to get a plumber to flush the system and re dose with fresh stuff
Watch the vid I posted will give you an idea what to do
Ian there anyone on this forum I can FaceTime this with as I wanna try to bleed it first and see if that fixing the humming noise in the pump and if not gen I will replace the pump and just re bleed it
Are both pumps around the same temperature to touch ?
Here you go I hope this helps
I realise that the wiring code in Canada may not be the same as in the UK but nonetheless... Assuming those are mains zone valves, your wiring looks unsafe to me. A competent electrician needs to rewire your zone valves with the correct type of cable and connectors.
They come like that I believe there low voltage etc you see most ca / us wired like that
Yes more less but I think one is for hot water and one is for heating that I have not used yet as I live in Vancouver canada and it is still summer here
You might be ok normally if it’s getting Goosed will run a lot hotter and won’t pump as well
Ok I see the pump maybe still ok but I have new one sitting but for learning purposes I wanna learn to bleed it first and then test if the pump was hiking air or if it is still noisy then I will replace it and bleed it again
[automerge]1567444184[/automerge]
Can anyone help me via video chat
[automerge]1567449838[/automerge]
Anybody able to help me out
Anybody ????
I just don’t wanna mess it up
[automerge]1567577461[/automerge]
Can you please help me
Anybody ????
Sorry no best get a pro out
I thought this forum is to help DIY People learn and ask advice cause I am a antique car restorer on many forums and lots of us share knowledge and experiences but I am not sure if I even have he correct forum
Reply to Need help bleeding system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
