Discuss Need help finding a white tap! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
SquiresPlumbing
Looking for a replacement for this Tap for customer can't seem to find one anywhere, as long as the body is where the heads can be changed to the current ones in use!
Any ideas where do them would be great.
iv already ruled out, plumbcenter, willbond, plumbfix, tradepoint, ghrayams
I've not seen taps like that for a very long time.
Why are you changing them, is the coating coming off?
I would have a look on ebay pal , I have had a couple of white kitchen taps off there this year .
If that is an Ideal Standard mixer tap, then it probably will be possible just to buy the body complete with works, but without the heads. The old heads normally still fit the new tap. That was the way those taps came, - body with choice of heads.
I know that because I have bought just the body and used original heads for a customer.
Tell your customer chrome would be so much better
I think you'll be mighty lucky to find a replacement white basin mixer that will take those tap heads, the bath mixer will be the same age so probably on it's way out too. Would be pushing for new chrome taps if that was my customer.
Sometimes you have to concede to the fact that you can't perform miracles.
If they are desperately attached to the bonny white mixer maybe getting it re-coated could be an option, lot of messing about though and would probably work out more expensive.
Reply to Need help finding a white tap! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one ....just easy to use and reliable. The fluke 115 looks good but its above my budget. My current socket and see one was great but it's developed a fault.
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
