Discuss Need thought on how to open up single lever tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. We moved into our house last year and the kitchen tap has been dropping since we've moved in. Finally getting around to looking at it! I'm guessing it's just needs a replacement washer or something, but I can't figure out how to open it up. Any ideas?
It's a Swan neck tap, with a single lever block to the side. I can't seem to get to the screws inside the lever block. And there's a small screw on the back of the neck area. Have tried unscrewing but the neck doesn't come off. I don't want to force anything in case I break it.
Have attached some photos. Any suggestions appreciated. I don't know the make or model of this tap.
20180330_110849.jpg 20180330_110853.jpg 20180330_110915.jpg 20180330_110933.jpg 20180330_110946.jpg
Easier just to change the tap. That one will need a new cartridge. Fine if you know the make.
As above but if you really want to the where I have circled in the pic. The little cap will pop out and will expose an grub screw inside. Loosen this and the lever will pull off and expose the cartridge
Reply to Need thought on how to open up single lever tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
