Discuss Nest and Indirect systems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tonym182
Hi
I'm moving house soon and the property has a gloworm combi boiler and a separate copper tank on the 1st floor.I think this is called an indirect heating system but I'm not a plumber.... It also has a separate expansion tank..
I'm thinking of getting Nest installed for savings but I found a comment in an article attached which has made me unsure.
"The main criticism is the Nest thermostat takes a fair bit of time to learn your preferences and you can’t pre-enter as many as you’d like. As such energy savings were reported to be between 10-25 per cent prior to the recent 4.3 update. Here the competition feels they can do better, quicker, while those with a separate hot water tank may find the Nest doesn't give them the control they need"
Can anyone help me with this comment in red and whether I should install nest.
Thanks for your help.
Regards
Tony
Nest no good for your Hw. You'll need a separate control.
Yep C/H biased.
But if you want same ch/hw times then nest ok.
If you want seperate ch/hw/ times then a tado stat is the answer.:coffee:
Reply to Nest and Indirect systems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, Just wanted to share my experience with "upgrading" an S plan setup to Opentherm and Vaillant Control Center (VR66). There are a few...
First post as I can not figure this one out. I have a hot water boiler heating system, gas fired, with an HTP SuperStor indirect hot water tank...
J
  • Locked
Hi Everyone, I'm looking for a little advice so I can try and save a bit of money this winter (especially considering the new prices!) I have an...
Hi Everyone, (not sure if my last post worked so apologies if this is a duplicate). I have an Ideal Boiler (vogue max system 18) and a MegaFlo...
Hi I'm looking some advice on the best heating setup for an existing system that would reduce wastage and save money. Current setup I have an...
