Discuss New cartridge in but shower head still leaks. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Does the cartridge form part of the on/off?
The cartridge sits inside the valve body. Hot water is supplied to a port on one side of the cartridge and cold water is supplied to a port on the the other side. The shower handle is rotated with the single lever shower handle to turn the cartridge from the "off" position through to the cold and hot positions. So, the cartridge is used to completely shut the water off as well as control the water temperature.
Reply to New cartridge in but shower head still leaks. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
I have a brand new, unboxed shower/wet room screen from KRION purchased from Porcelanosa UK. It is the Attica 1 model, as shown in the attached...
Sebastian T
I have done pressure test for 2" high pressure pipe line by closing the pipe with rubber plugs at the ends. It was 3 bar and I kept it for 24...
