Discuss New Central Heating with 10mm pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I recently purchased a cottage type bungalow and currently there is no central heating in the house only electric storage heaters.
I am in the process of removing all the storage heaters and installing the new central heating.
All the floors in the house are cement and all the exterior and internal walls are full of king span or glass wool insulation. Making it a real headache to get pipes to the radiators.
My plan at the moment is to run 22mm flow and return from the boiler into the loft space to 22 x 10mm manifolds and drop feed the radiators down behind the walls and then behind skirting boards and up to the Rads. Most of the Rads will be underneath windows. All runs of 10mm pipe will be +/- 5m flow and 5m return back to the manifold. The largest radiator in the house will be 1100 x 600 double, 8 x Rads in total.
I also plan to fit an indirect unvented cylinder in the loft space and pipe the coil in 15mm.
Central heating boiler is a Firebird enviromax outdoor oil boiler.
I know a lot of people don’t like to use 10mm for central heating but seems to be my only option without channelling the cement floors.
I have recently read that a lot of new build houses central heating systems are done a similar type way. Do you guys think what I have described will work OK with the length of runs of the 10mm pipe?
Thanks in Advance
As above, for the safety of yourself, your family & your neighbours, please get someone who is G3 qualified to fit the unvented cylinder.
With regards to the piping, if I was in your position I would go for 15mm and channel the floor if need be. Seems a shame to go to all this effort only to stand an increased risk of blockages and issues further down the line that will be expensive & disruptive to fix.
Also as a general rule of thumb, anything that is common practice in new builds is almost certainly not best practice.
Appreciate the reply's.
For sure I will have qualified Plumber to fit the boiler and cylinder.
My plan to reduce cost was to rough in all the pipework and have a plumber do the final install.
Agreed 15mm would be much better than 10mm.
But do you think it is possible from what I described for the system to work OK if well maintained and plenty inhibitor?
It will work if executed properly alot of new builds are done that way the boiler and unvented cylinder are notifiable so will need fitted by a registered installer , any work you carry out yourself will need checking and pressure testing . Kop
No matter how much you ask us Mr1981 ...you will get the same general reply ...22mm main supply and 15mm to the rads. Plus the visual effect of microbore to the rads and anywhere seen ...immediately
says old, amateur , skin flint
cheap etc. if you will want to extend or sell on your plans for
microbore are plain wrong.
centralheatking
Reply to New Central Heating with 10mm pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
