Discuss New hilmor pipe benders marking pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have just bought some new hilmor pipe benders that are nicking the pipe on one side of the pipe when I pull a 90 degree bend on 15mm copper. Any one know a cure for this?
Are the alu bits free of dirt and damage ?
if you can post a pic up of the nicking
Try tightening the nuts up a bit on your bender, only hand tight mind you or you wont be able to move them!
Thanks that has helped. When you pull a bend with a machine it makes the pipe on the bent part a smaller diameter. Guessing this is no problem to the flow?
It's not much and will be less resistance than a fitting
Thanks my worry is for 22mm heating pipes. When putting a machine bend on this will not effect the maximum btu loading of the pipe?
You will be fine been done for ages
cant post URL but:
Irwin Hilmor GLM Pipe Bender - Screwfix Product Code: 63880
I have that exact one and its fine for both 15 and 22 bends.. no nicks or creasing.
Reply to New hilmor pipe benders marking pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
