Discuss New home owner. 10k pipe problem? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
L
LauraD383
My sewer pipe got clogged from flushing paper towels. Rotor rooter came and unclogged it. They also sent a camera threw it. These are the options they gave me. Does this seem right. Are these prices accurate?
#1 jetting ( $1760) this is the minimum you can do will buy you time but only so much depends on flushing habits ect...
#2 trap removal and jet ($2500) this is much better then just jetting but it's still a bandaid to buy time
#3 trap removal, maxi milling "Sanding " and jet ($6500) this is a great option to set the clock back and make everything you flush a smoother transition pipes will corrode again but it will take a long , long time to get this bad again
#4 trap removal jet and liner ($14,500) this is by far your best option but also the most expensive.
#5 full line replacement all new pipes from foundation to city sewer plus trap removal ($19,900)
What did they say the problem was ?
Reply to New home owner. 10k pipe problem? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
