Discuss New oil boiler question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dogbower
Hi, I am just after some advice on a new oil boiler.
Inherited an old Worcester heatslave with the house, Have since installed underfloor heating throughout the ground floor, and converted the attic which runs off radiators. This system all works fine with our old boiler.
I am now looking at replacing the boiler, looked at lots of alternatives but decided to stick with oil.
Question is to stay with combi or go unvented and heat only boiler.
Just the 2 of us, at least 1 shower a day, I understand heat only boiler has less to go wrong, but cant get my head around heating a cylinder for just us 2.
What do you think?
Unvented is best way to go with heat only boiler. You need to size it accordingly and when it gets heated up after about 30mins it will stay hot for a long time. Combis give more trouble will be more expensive to repair and will cost about same as a boiler and cylinder. Also if boiler breaks down you still have hot water with better pressure.
Unvented Grant, make sure you've definitely got a big enough vessel, standard with the boiler usually isn't big enough!
Go for an external Grant, then no oily muck inside your pad!
quicker bath fills, better flow, 2ndry return gives hot at taps immediately if you want, immersion means back up to boiler, happier oil tech on servicing and repairs, anything else?
where are you so someone on here can quote?
Reply to New oil boiler question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs...
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
My daughter bought her first home and was hoping to convert to gas but its not available in the area, so thinking a boiler upgrade is the better...
