Discuss New regular boiler (heat only) in a sealed system?? in the Central Heating Forum area at PlumbersForums.net
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig cupboard & a megaflo (no tank in loft). However the exisiting boiler is Vaillant ecoTEC 4xx boiler - which is satated by vaillant as an "open vent" boiler (has no internal pump). So at least in theory I have been running with the "wrong" boiler for 11 years...??
I have asked for quotes from 2 local plumbers and initially they both recommended to replaced like for like and stay with the same boiler.
This is a large house mainly with UFH (3 manifolds and 3 small rads upstairs).
Just heard from one of them that he now realised I need a "system" boiler and therefore I should fit an ecoTEC plus 6 (not 4!)
Question(s):
Can I install an "open vent" boiler in a sealed system without invalidating new boiler warranty?
If I can not and it must be defined as a "system" boiler, what do I do with the exsiting CH pump (in airing cupboard)?
Can the existing pump be made to work with the internal pump of the system-boiler?
Is there a risk the 2 pumps will create too much pressure in new boiler?
Thanks in advance!
Open vented boilers can be fitted on either a open vent eg gravity system or a sealed system eg with a red expansion vessel etc better in my opinion as they don’t use expensive and manufacture only components eg pump, expansion vessels and diverters
You would have to remove the external pump
Stick with heat only. You most probably still require an additional expansion vessel due to system volume if its got underfloor heating and you wouldn't gain anything by conversion to a system boiler apart from more things to go wrong.
Reply to New regular boiler (heat only) in a sealed system?? in the Central Heating Forum area at PlumbersForums.net
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I...
A (if) CH system has a very high head loss due to improperly sized pipework and long runs and possibly partially blocked pipes and requires a UPS2...
Hi I seek some advice on replacing an existing regular boiler. I currently have an old Potterton 10-16 Netaheat electronic, which is around 35...
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the...
My disabled daughter’s hot water has stopped working. It’s a relatively modern Potterton boiler with an indirect sealed hot water system and a...
