Discuss New set of Allen keys in the Plumbing Jobs | The Job-board area at PlumbersForums.net
djob
Hello I'm looking at buying a new set of Allen keys, just curious to what you guys use or would buy? I'm fed of sub standard Allen keys bending!! Thanks
what you doing with allens keys?? hes not in between 8 and 4.30 if it helps ;)
Nothing specific right now but there is always a time when you wish you had them on you and as the cheap ones I have just ruin my day whenever I try and use them I'd like a decent set..
Bacho set £20 and machine mart ones 7.99 on a rail. When I loose them or some on nicks them it's no big deal. Now a beta or snap on set would make u angry
I also got feed up with bad allen keys. Got a wera set from screwfix for about £20 and are excellent
Reply to New set of Allen keys in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
I have an Arteform shower valve in my bathroom - top lever for the main shower head, middle for the handheld hose and bottom is the thermostatic...
M
If I dropped an Allen key down a drain, do I have to get it out? What happens if I don't will stuff just build up around it and eventually block...
I’ve cleaned the grooves and tightened the grub screw at the bottom, but this tap handle (on the right of the photo) just won’t stay put. When...
Hi all. Sorry I'm not a plumber so go easy on me. I have a triton shower (see images) below, I don't know the model as it was here before me...
Deleted member 120897
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the...
