Discuss Allen key down shower drain in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
M
Melanie
If I dropped an Allen key down a drain, do I have to get it out? What happens if I don't will stuff just build up around it and eventually block the drain ?
Reply to Allen key down shower drain in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Please see attached pic. . . . I would like to replace the drain cover in my ensuite shower. Also, I am hoping, if possible, to replace the top...
J
I have an Arteform shower valve in my bathroom - top lever for the main shower head, middle for the handheld hose and bottom is the thermostatic...
I’ve cleaned the grooves and tightened the grub screw at the bottom, but this tap handle (on the right of the photo) just won’t stay put. When...
Hi, As per title we have a regular smell from the shower trap. Clean the trap twice a week, had a cleaning rod down the shower waste pipe and no...
Hi, I need some help on this shower drain installation. I’m about to install a corner shower kit in my basement bathroom. But I just found out the...
