Discuss New shower pipe centres in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I have a shower which has pipe centres of 110mm. Looking for a new shower but it looks like all the modern showers have a pipe centre of 150mm. Is that correct and if so, is the only solution to replace the plumbing?
Thanks in advance
Ian
Think Mira do an adjustable one eg one of there exposed
Reply to New shower pipe centres in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have a leak from my shower, it's coming down into my kitchen. I've had the sealant, waste pipe and tray all checked. I've also had the shower...
Hi all. The current towel rail is 1000mm x 600mm and ideally I'd like the pipes coming straight from the ground into the rail. The distance...
I'm at the stage of my shower replacement where I have a new shower head to screw into the wall pipes. I tried it, turned on the shower, and find...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
