- Messages
- 3,071
New Surestop product, what do you think?
SourceSurestop have introduced a new fitting that allows direct connection between MDPE and Copper or Plastic pipe work and includes a Surestop stop valve.
By combining the John Guest MDPE push fit with the Surestop Stop Valve (both WRAS approved Products) the Surestop MDPE connector provides a fast and easy method of connection between the external MDPE pipe work and the Internal Copper or Plastic pipe work, therefore saving on installation cost.
The Surestop Stop Valve used is the upgradeable version that allows a remote switch to be added at a later date.
Sizes available
MDPE mm to Copper/Plastic mm
20 15
20 22
25 15
25 22
The MDPE fitting is push fit only
The Copper/Plastic can be push fit or compression.
