Discuss new wc needs plinth in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Evening to the Forum. Customer has asked for an old Fordham to be
replaced. The new wc's spigot is lower.What do other members prefer
for the plinth, W.B.P or M.D.F ? Thanks, Dean.
I think he may be putting in a close couple pan and cistern Steve and the pans outlet is lower than the soil pipe connection regards turnpin
If you must use something for the plinth I suggest some marine ply regards turnpin:20:
ah! of course just having a dumb moment lol
Seen it done in cement before. You could pack it up to the right height, and pug it up there?
I've used offsets for downward slopes. Thought it not done for upward because
connection always in water/ p**h trapped on step. Advice appreciated here.
I didn't fancy s&c as it's on floorboards, I think pug dries out too quick, and
boards flex. Thanks, Dean.
If it's on floorboards then it has to be timber really. Won't be hard to do I'm sure. Might look a bit weird!
I did wonder what customer would think of my bit of 18mm ply
If it wasn’t the downstairs spare. Thanks, Dean.
use an AKW white plinth if your customer wants to pay for it. around ÂŁ100-ÂŁ150 dependant on height and discount.
Very expensive for a bit of ply and fibreglass but they're definitely a tidier solution. This is one I fitted, to give you an idea:
cut the soil back flush to the wall and use a long tailed pan con due to the angle most old pan were connected at you can just get it level/falling by this method
Reply to new wc needs plinth in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
