Discuss no hot water from indirect tank .help needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi,all
I have an indirect unvented tank for hot water, but no hot water getting to coil inside,system boiler, heating all else,underfloor heating,no motorised valves, I have drained system,disconnected coil put a hose inside coil and flushed,refilled system, removed air, no success. any ideas??: i am using the immerser in tank just now.sweatdrop:
(joiner)
Hello and welcome. Do check you have no motorised valves with cylinder stat (most systems now have them somewhere) or thermostatic valve for cylinder jammed closed.
Other thing it can be is a gate valve broken or shut down - it can be there as a balancing valve.
Other option is dirt in pipes to coil, which is more likely if it was a previously open vent system
thanks,defo no valves,no gates,wasnt open vent, had new boiler fitted,6m ago, all working fine till now, prob need flush whole system.?
unvented cylinder will or should have a motorised valve and to work on one you need to be registered
thanks,but defo no valves,as i have moved boiler from orginal place.i know its strange but thats the way system was installed by orginal owner so you get free hot water as it heats underfloor heating,
if it is unvented and no motorised valves there are serious safety issues, get someone in to look and make safe
I missed the word unvented! Definitely should have a motorised valve for the unvented cylinder (they all come supplied with one as part of their safety parts)
Get a G3 qualified person to take a look at it, and while they are there tell them to service it, as it must never have been installed or serviced before by anyone who knows what they were doing.
They can also explain how you can continue to get the free hot water when the UFH is on. LOL
& you have been moving your boiler as well, if not windup, dear God get some who knows what they are doing to come take a look quick before you kill your loved ones.
no such thing as free heating if its heating water its costing you money in fact by the sounds of it your heating the cylinder with no way to controll it which will be costing you money
this is a system i would love to see photos of
I was going to ask a somewhat pertinent question which would really put the cat amongst the pigeons. However, I won't.
What I will tell you is that you need to get a g3 and gas qualified plumber in sharpish.
Job 38.11.
Reply to no hot water from indirect tank .help needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have hot water, tank for hot water why is the hot water boiling hot from tap,and shower, We are on a schedule for hot water via our hive app...
Sonya K
