- Messages
- 144
I think he means even more scary - using the boiler!
Hmm, I think I'd need a pair of the The Wrong Trousers to try that one ;-)
Discuss No Hot Water - Gravity Fed System in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pull stats and boil it.
Ok, so I went back last Monday and, before checking pipework with a magnet, turned the hot water and heating on. As previously stated, the hot water cylinder is in the loft and the flow/return pipe run from the Rayburn in the kitchen to the cylinder in the loft (via pump & diverter valves under first floor hall) is about 30-35 feet. After turning the hot water/heating on, I went straight up to the loft to check the cylinder (took a couple of minutes at most) and the flow pipe to the cylinder was already getting warm and after another minute was hot. However, after a few further minutes, the return pipe hadn't warmed up at all.
I then part drained the system, disconnected the flow/return from the cylinder and ran some water through the cylinder (not mains pressure but using a bottle of water) and, apart from a bit of discoloured water coming out the other end, found the cylinder coil to be clear.
I've checked 50% of the flow/return pipework to the cylinder with a magnet (the other 50% is in a difficult to access loft/ceiling void) and it's clear.
Surely, if there was a blockage, there's no way the flow pipe at the cylnder would have warmed up so quickly (if at all) as there's no where for the water to go !
Yes, the flow pipe can heat up fairly quickly as it is only the water in the pipe heating up. It may only be passing through it very little due to a blockage or air lock. I see this very often on a cylinder with return pipe nearly blocked totally. Something strong, but flexible pushed down into pipe would be handy.
Airlock.
When u emptied the system did u manually open the zone valves to allow proper filling of the system , ?
Reply to No Hot Water - Gravity Fed System in the Plumbing Jobs | The Job-board area at PlumbersForums.net
