Discuss No hot water - Oil fired boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
HPPH
Can anyone help please? I have no hot water and the oil fired boiler is not firing up ( programmer as normal )
There is a white box on the wall ( House sitting for Dad ) called a watchman flashing a 'c' at me. Does this mean I have run out of oil?:confused:
According to their website:
"This indicates that damage may have ocurred
to your Watchman transmitter and it has an
internal fault. A replacement product will be
required, please contact Sensor Systems"
Unless, of course the right hand part of the 0 has stopped working then it will look like a C!!
I'd start by ignoring this and checking the level of oil in the tank.
yeh,probably your dad is using the oil money for holiday money !!
not worried about the poor house sitter !! :p
Thanks for advice dontknowitall. Will check manually. Thanks again
Yeah probably. Have starting feeding the back up hotwater stove with a variety of kitchen furniture ....?!!
Switch off the watchman and unscrew the battery off the sender at the tank. Wait 2 mins, turn it back on and then screw the battery back in.
Thanks Croppie. Will try that now. Cheers
Hi Croppie, I have tried as suggested and now stopped flashing and reads an ' f '. Possibly means ' Fault ' although the transmittor seems to work still ( noise ).
Will call Watchman direct unless any other anyone has any other ideas?
Thanks again
Now back to flashing ' C '! - will call sensor systems
Reply to No hot water - Oil fired boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
