Discuss No vent pipe from cylinder? Help would be appreciated. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello,
I thought I’d try fitting a shower pump today. Every thing works, other than the pump just fires water up the vent pipe and into the tank in the attic.
i don’t know where this vent pipe has come from as there isn’t one coming off the top of the cylinder.
Please put it back how you found it as the vent is the cylinders safety feature and atm you’ve basically capped it off
Have a look at an s flange
I see that now.
what a pain. Thanks for the advise
will an S flange work with that set up? Usually there’s a vent pipe and the pipe to the services, I only seem to have one. Which is why I thought the system must be vented some other way.
Would I be right in saying the pipe to all the services must T off that vent pipe somewhere else (floorboards above the cylinder probably). i need to put the pump on to that pipe somewhere, preferably below the hot water cylinder.
Right connection to pump then going to your outlets that want to be pumped eg shower etc
Top connection vent and any outlets that you don’t want pumped
Capping off the vent pipe risks implosion of the tank. Reconnect the vent pipe and do not run the pump.
If you want a simple installation go for a Shower Power Booster. There is a link to the site on this forum.
In some circumstances, the cylinder without a vent could even explode. For example in overheating conditions, or if the water is being heated in normal conditions and if the cold feed to the cylinder is isolated.
If you're committed to a conventional pump rather than the Shower Power Booster suggested, look at page 40 on Mira's Guide to Pumped Showers (q.v.) and note the vent arrangement used. Or you can use a flange as suggested. The vent must always rise continually from the top of the cylinder and there must not be any form of isolation valve on the open safety vent.
Please check what you do with us before you switch anything on (especially the water heating). These photos are a bit scary to be frank.
I can’t really do that set up without re-plumbing my whole house as all the outlets must t off the vent pipe somewhere else. There is not pipe to out let’s in and around the hot water cylinder, just the vent pipe.
[automerge]1570990304[/automerge]
Yup, I know. I didn’t realise that the pipe I was using was a vent pipe. Which i now know sounds ridiculous.
Can’t use a pump then sorry to say
I wanted to use a flange, but there’s only the one pipe coming out of the cylinder, so a flange would involve a lot of re piping, taking floors up etc.
[automerge]1570990526[/automerge]
I’ve found a pipe running behind my kitchen units to the shower/bath. I think I could put the pump on that pipe?
Shower Power Boosters are designed to fit anywhere on a system. Cut out 115mm of pipe, Slip in a pump, pug the transformer into a standard 3 pin plug. Extend the power suppy with a low voltage extension lead if needed. No major pipe modifications - no need for a Surrey Flange. 10 minutes work and job done. If you fit a normal pump on a pipe some distance from the cylinder the high head loss could cause cavitaton, the big pump burns out, and you invalidate the warranty. SPB can never cavitate or burn out. They are designed to sort out difficult jobs like yours.
The manual does say it needs to be within 5m of pipe work to the cylinder. I’d have to measure, but I’d say I’d be slightly over.
Could you possibly send me a link to the SPB you’re talking about? Ive googled it, but all sorts comes up.
I do appreciate all the help and advise. Thank you. Probably should have come here first.
There is no limit to how far a SPB can be from the cylinder. A link to the ShowerPowerBooster web site is in this thread which I sent an hour ago so you can click on that link or you can click on the blue banner on this site. Contact me through the web site and I can advise you further. - Alan Wright
There's only the one pipe coming out of the cylinder? Presumably, then, at some point (probably above the ceiling) you'll find a tee off to your taps, showers etc. Logically the water must have been getting to your outlets somehow and this would be the pipe you'd need to be pumping into. I'd prefer to see a pumped pipe serving just the shower, but depends on the circumstances how useful this would be.
You can believe Alan Wright on the requirements of the Shower Power Booster seeing as he's the inventor of it.
From the assumptions I have to make, not having seen your house, I'd be inclined to say don't put your pump in the kitchen. Alan Wright has suggested his product may provide an alternative that may be more acceptable to you than extra pipework, something you seem to be dead set against.
If plumbing were easy, I'd be out of a job :)
That’s the assumption I’m making (after a day of learning about plumbing 😂). I think it goes up, tees off through the floor boards then back down to the kitchen and then then to the bath/shower.
so I have 3 options as I see it:
1.put the pump I have in kitchen, which would put it out side the manufactures recommended distance from
water cylinder and by the sounds of it, break the pump.
2. Find where it tees off, remove it from the vent pipe and replumb that back down to the cylinder into an Essex flange, creating the ideal place for the pump I have.
3. Fit one of these SPB things that Alan Wright speaks of.
I’ll have to think on it. option 2 is what I would do in an ideal world. But it’s time and money. Maybe I’ll try option 3 and if I don’t love the results I can look at option 2 again.
at least I’ve learnt a thing or two about my houses plumbing if nothing else.
I've never fitted a Shower Power Booster myself, not because I think there's anything wrong with them, but simply the occasion has never arisen, so please do let us know how you get on with it if you go down that route. Let us know how you get on anyhow - the curiosity is probably what makes plumbers on this forum think it's worth their while.
I will certainly let you know. Need to recover from my wasted Sunday/money first of all 😂.
You appear to have a downstairs shower which means that it should have at least 5 metres of pressure at the shower head already so you should already have enough pressure for a good shower without boosting. A Shower Power Booster will increase the pressure to an upstairs shower by x3 to x4 and the flow by x2. In circumstances such as yours where you already have good pressure a single boost SB2B will only give a 25% increase in flow and you should consider double boosting with a SP21S on the hot as a minimum.
Your problem appears not to be pressure but that your shower and/or shower mixer are at fault in not using what pressure you have already got to give you a good shower. There are advice pages on my web site which advise you on what you need to be looking for if you need a new shower mixer, shower head, or shower hose.
If you contact me through the web site I will send you the advice links so you can make an informed decision but just fitting my pump or indeed any pump to increase pressure when pressure was not the problem in the first place is not going to make you happy.
Cut a tee into horizontal pipe out of cylinder. Middle outlet pointing down. Take this connection to pump inlet.
Connect the 22mm back up you've cut out.
Lift floor above and cut and cap the not water feed where is is teed off of vent. This re instates vent.
Cut back the hot water feed and take a new pipe down to pump outlet.
I’m glad you said this, I’ve been thinking about it today and I think this is what I’m going to do. Bit like this...excuse the poor diagram.
Hello,
i don’t know where this vent pipe has come from as there isn’t one coming off the top of the cylinder.View attachment 40861View attachment 40862
Hello, the vent pipe is for expansion and stops the expansion caused by excessive heat to hot water supply from damaging the pipe work or boiler. I fitted power pump to my system with the same type of expansion and the only time water is pushed out of the expansion pipe is when the pump is activated while all hot feeds after pump are shut off otherwise it works perfectly.
Reply to No vent pipe from cylinder? Help would be appreciated. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I recently did some pipe insulating in my loft. The only two I didn't do were the vent pipes. Not sure if that is the right term for them...
Hello. I am planning to build a small half bath in my garage, next to a washing machine, using old showers plumbing. There was a stand-alone...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built...
    • Funny
Hi guys, I have a question regarding converting an open vent system (copper cylinder) to pressurized, reason being not enough drop from the loft...
1K
