Discuss Oil boiler cirtifcate in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Ashleygaynon
Hi, my builders plumber has done a great job ,on complex first and second fix to my extension, he fitted a new boiler all working perfectly , although when it's come to getting the work signed off. He has become very difficult to get hold off . Does any one know of someone to sign this oil boiler off ? Chelford cheshire , any advise welcome please
thanks
Maybe your builders plumber hasn't the qualifications. Did he commission the oil boiler?
Needed an analyser to set it up. Also has to be fitted to regs, - proper remote fire valve etc.
Get a OFTEC oil engineer, who is experienced in to have a look at it all.
Some of the oil engineers local to you on this forum might help, but I doubt if they will be happy signing work off that is not there own, which is what you require
Put it back to your builder, as he is responsible to have your job done and passed
We have exactly the same situation on a job tomorrow, we are comissioning it but the builders have to certificate it via BC.
We are relatively local to you, recently put a biomass system in at Chelford House, so might be able to assist with the commission but not the sign off (we are OFTEC)
Hi ok that's sounds good, please can you contact me on 07747068525,regards Ashley
Would really recommend you pm Jong1 direct rather than putting your number on open forum
Reply to Oil boiler cirtifcate in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I recently had a renovation done. My builder installed a new Combi boiler instead of my system boiler. He connected the pipework to the...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
Any advice welcome as plumber stumped Had 36-46 grant vortex utility boiler 7 years no problem recently oil tank move and tigerloop install...
Hello, We had an extension built seven years ago. Initially the builders' plumber connected the heating to the house system but this didn't work...
I have a "Firebird Envirogreen Condensing Combi Oil Boiler 26kW" a part has went and I can't find it anywhere, I was at every plumbers merchant...
