Discuss Old cistern replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dparker357
hi guys I would be great full if someone could tell me if I could replace this old type cistern for a new modern cistern using the exsisting pan. Is the connection to the pan likely to be different?
Buy a new external flush pipe connector to replace the one on the pan. This will have gone hard and won't come with the new cystern
Thanks for the advice will do! Also one more thing I can't seem to find a modern cistern with the same litre capacity as the old one I would imagine it would be 9-13 litres right? Does it really matter if I use a 6 litre cistern as that is all that seems to be readily available
You won't find any that are not 6 litre. They will be a similar size to yours, but the flush valve , or syphon will determine the ammount of water for the flush .
More problems sorry to say what you doing with that lead supply :(
What's wrong with the existing cistern?
the lead supply is being changed for copper and the customer would like to change the cistern for a more modern looking cistern. However most of the low level cisterns with a 9 litre capacity or more don't exactly look great as they are made of plastic.
Reply to Old cistern replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
  • Locked
Hi All, I am a 16 year old school leaver (Sept 23) looking for a local company to take me on as an apprentice plumber. I live in Benfleet and am...
Billy Barnard
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
