Discuss Old sewer pipe fitting for rodding access in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'd also put a strap wrench around the the collar to ensure that when you try to unscrew the cap you don't torque the entire length and break the weakest joint, which Murphy's Law guarantees will be the least accessible.Normally I would say a flat bar over the lug on the left and under the lug on the right as per the photo
This should do it, more than a tap though, use a 'mash' (club) hammer and give it a whack, that should crack the seal which is all you need. Shouldn't need to worry about rest of the pipe it's cast and very solid.and don't forget anti clockwise, tapping your flat bar with a hammer to start it off
Reply to Old sewer pipe fitting for rodding access in the Plumbing Jobs | The Job-board area at PlumbersForums.net
