Discuss One isolating valve on both loft tanks inputs? in the Central Heating Forum area at PlumbersForums.net
Hi, just after the mains stopcock under my kitchen sink I have a tee, one pipe to drinkable water+washing machine and the other to the loft cisterns (talking about an open vented pumped S-plan system, standard here in UK).
I was wondering whether it is safe to add an isolating valve on the latter pipe, placing it right after the aforementioned tee (i.e., under the kitchen sink).
I am asking because I've read somewhere that the feed and expansion tank shouldn't have a valve on its input, but I couldn't find a consensus on that, online.
I am also suspicious because currently I have an isolating valve just before the bigger loft tank in the loft, not serving the FE tank. Which could be a hint that FE shouldn't have an input valve?
1. No reason why there shouldn't be a valve on the input to the F&E tank. Clearly there shouldn't be one on the vent pipe.
2. If you are going to fit one, I'd make it a good quality, full bore lever valve, such as a Pegler.
Thanks. This then brings me to a second question: any clue why my system currently has one valve in the loft only serving the storage tank?
I only see disadvantages in this choice, as compared to having one underneath the kitchen sink serving both loft cisterns: the latter i's easier to access, has less freezing chances, and you can serve both tanks with one valve.
I am just curious why the plumber originally chose to do that. Maybe the FE was added at a later time?
Most likely added at a later date, and perhaps it was felt unnecessary to provide separate isolation. The usual trick was to tie up the float valve, but not much use if that was what your were changing!
Reply to One isolating valve on both loft tanks inputs? in the Central Heating Forum area at PlumbersForums.net
Hi, Throughout our house there are numerous isolation valves which are on almost every plumbing fixture. Clearly whoever plumbed this had a thing...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
… praying to the plumbing God, Bob Pictures and layout details attached, so be patient. 21 year old oil fired system in pretty good nick. I...
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
This is doing my head in, so I am turning to the experts here for any wisdom... In the last couple of days I have very low cold water pressure in...
Deleted member 120897
