Discuss Outdoor garden tap not working in the DIY Plumbing Forum area at PlumbersForums.net
Hi
Our outdoor garden taps do not work, to be fair we haven't used in years, but would like to start using it for gardening projects. No water comes out of the tap at all. How can I switch it on, our mains is on as we have running water inside the house
Does the valve inside the house feeding outside tap have a handle on it? Could have turned the handle but not the valve. Take off handle and check.
Could be a double check valve tap. Prone to going the journey. Take the hose spout off and if you see something plastic inside then poke a screwdriver in it.
The issue, is I am not too sure about where the valve is inside the house, what would it look like?
[automerge]1588837319[/automerge]
Were your outside taps working before?
Yes a long while ago
Reply to Outdoor garden tap not working in the DIY Plumbing Forum area at PlumbersForums.net
L
We're in the process of doing grounds work for a new garden office, and unfortunately my go-to plumber is away and uncontactable at present. We...
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A...
