Discuss Outside tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
marsaday
I am trying to find an outside tap on tool station, but cant seem to find what i need. It needs a back plate so it can be secured to the wall. Also do they come in solder, push fit or compression ?
Any links will be appreciated.
You lot must be linking several of those ugly flexies together to do an ootside tap in half an hour. Most of the ones I've done take around an hour.
Well this is my outside tap kit. ;) $(KGrHqZ,!ngE-5UJRT-wBP1lE!plp!~~60_12.jpg
Just stumbled upon this on ebay. 99p at the moment Sys3. You could bag a bargain!!
http://www.ebay.co.uk/itm/FLEXI-TAI...DIY_Materials_Plumbing_MJ&hash=item20c6b03665
I know. I'll get banned at this rate!!
I've got paper work to do now :(
While I was on ebay I also noticed this:
small header tank | eBay
Basically someone who's had a combi fitted is trying to sell there old header tank on ebay. Mental.
1/ Who's going to buy it?
2/ If someone does, how tight are they?
These are our customers. Scary.
Have a good one all.
JG Speedfit do a push fit double check valve but it's way overpriced. A standard compression one is better. The bib taps with the built in DCV don't last in very cold weather, even with the tap drained, so a separate internal one is the best solution. Don't forget to fix an isolating valve so that you can turn the tap off and drain it in the winter.
Always drill from the outside so that you don't burst your wall.
I always drill half way from outside & halfway from inside but I am extremely clever.
Agreed. No one drills half way from each side. You'd have to be more than clever to line them up. You'd have to be a freaking genius. Like the Rain Man of drilling.
Possibly you pilot all the way through and then drill each side with a bigger drill?
That's what I thought at an absolute push!
If you hurry up Danny you may get it. 8 mins to go and still at 99p.
Was tempted to put in a bid myself( :lol: ) as the galvy one on the job i was at today is ready to drop the rse out of it. Luckily i had an old one in the garage that will do me. Just need to find somewhere to put all my drain test stuff now :smile:
I have been fitting outside taps for years, but have never, ever fitted one 1/2 hour. I suppose you could do it that quickly with a cheap B&Q self cutting crappo fitting.
Thats because you are a handyman and we are pros.
5 minutes to get the gear out the van, another 5 to drill a hole, 10 minutes to fit the pipe and tap and 10 minutes to drink your luke warm tea and get weighed in.
Years ago a mate of mine working on the sites used to card every new owner £40 a tap. He fitted one in just about every house. It even got to the stage he was sticking a bit overflow sleeve through when he roughed them out.
Noo that's class!
Yeah, very sensible, & doesn't it depend on the drill, also how hard you push, my Bosch will punch a chunk out like a dum dum bullet but I've got a weaker hammer drill that just gently taps it way through.
Of course I don't! Unless it's a stone wall Devon cottage & 600mm won't go all the way through & now I'm not joking. Did one last week to feed a washing machine in a porch, admittedly I took a whole stone out one side.
Reply to Outside tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
