Discuss Pacific syphon on WC in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
Does anyone know if you can get pacific syphon anymore. i have been to check a wc which has an intermittent leak. Clean the limescale off the washer but did not solve the problem but looks like I will need to replace the syphon but I am unable to track one down
any help anyone
thanks
" Toiletspares.co.uk " say it is no longer available but have a cable one to replace it.
I take it by " syphon " you meant flushing valve? If cleaning the washer doesn't solve it, try reversing washer. Some washers, I notice, blister & let water past them.
yes noticed the ptfe ones used in grohe flush valves very prone to this they sort of bubble
If you take a photo I think I have a new one which I have in my spares.
Reply to Pacific syphon on WC in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. Water is slowly leaking into the toilet bowl from the cistern. I suspect that it's the rubber washer at the bottom of the tube that's the...
Hi I recently fitted a brand new Macdee syphon into a toilet and 4 weeks later it is broken at the nut which allows it to be serviced. When...
I removed an old shower hose, which was installed by previous home owner at least 12 years ago. Upon removal, the connection is like nothing I...
The syphon activation cable on my old Bathstore A2432 dual flush valve has broken and I don't want to have to remove the whole cistern to replace...
2K
Hi all. Not sure if it's a plumbers job or another trade but thought I'd ask. I am installing a new toilet downstairs next to an outside wall...
