Discuss pcv to clay waste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gates1979
I am fitting a new drain in my garden as the old clay one had cracked and was leaking i have dug down and removed the old drain and trap. I understand that i have to cut the old joint off the clay pipe thats in the ground and get a adaptor so i can fit 110mm pvc pipe to the old clay pipe the internal bore of the clay pipe is 100mm so there is going to be a step where the 110mm pvc joins the clay. Can you buy a connector that goes inside the clay pipe almost like a pan connector
Use one of these
[DLMURL="http://www.flexseal.co.uk/productpage.php?ID=14"]FLEXIBLE COUPLINGS - Adaptor Couplings (35-420mm diameter)[/DLMURL]
Measure the od of the clay and get one to suit.
Sold in most plumbers/builders merchants
Reply to pcv to clay waste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
