Discuss pipe lagging in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
katieheaney
Hi. We're building a new storey and half house with timber joists. Is it advisable that all the pipes should be lagged or just those running through the eaves?
thanks
Thanks. We thought so but plumber and contractor said that pipes in eaves only ones ever lagged with timber joist floor. We'll just have to insist that they do it!
Hi. It not good practice to run pipes in the eves. If they are coming up from below and the bending into the core of the property that fairly standard, but not parallel with fascia. Good Luck
Reply to pipe lagging in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
