Discuss pipe lagging in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
katieheaney
Hi. We're building a new storey and half house with timber joists. Is it advisable that all the pipes should be lagged or just those running through the eaves?
thanks
Thanks. We thought so but plumber and contractor said that pipes in eaves only ones ever lagged with timber joist floor. We'll just have to insist that they do it!
Hi. It not good practice to run pipes in the eves. If they are coming up from below and the bending into the core of the property that fairly standard, but not parallel with fascia. Good Luck
Reply to pipe lagging in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
Hi could anyone give advice please ? I went to look at a new build for sale they are apartments/ one house on top of another all properties will...
Hi all, grateful for your expertise on the following. DIYer, not pro. Rural property in France Single storey. Septic tank. Late 80s construction...
Hi thank you for letting me join this forum . We have an air to water heat pump but the bungalow is piped in micro bore 10mm pipe which doesn’t...
