Discuss Pipe seal for flat roof in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I want to run a 15mm pipe through a felted flat roof. Does anyone know of a collar or seal I can use to weather it?
Can you not just seal around and use a talon collar? https://www.NoLinkingToThis/p/talon...xUTcPXLFK4SiKaeetgtsHHm7zYicSjWAaAmkmEALw_wcB
And of course insulation.
Reply to Pipe seal for flat roof in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
