Discuss Plastic pipe thread snapped off inside compression fitting - how to remove? in the USA area at PlumbersForums.net
Hi
The fitting is brass (though doesn't look it in photo), the stuck plastic threaded pipe section is off the bottom of a standard ballcock assembly (bottom inlet) . It's snapped very cleanly, dead level with the nut.
So, any smart ideas on how to get it out?
Reply to Plastic pipe thread snapped off inside compression fitting - how to remove? in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
