shezzaar
Hello guys,
We are currently renovating a property. The first fix plumbing has been done in plastic (speedfit).
Today I have been trying to fit the pipes in for a new kitchen in plastic pipe (plumbsure). My connections and inserts are also plumbsure.
Everything works well on the first fix, and the pipes I put it are all strong connections. But when my pipes are connected to the first fix pipe the connections are loose when pulled.
Its all in 15mm pipe
Is this because the pipes and connections are made by different companies?
If so is there a way I can connect both the pipes without having to get speedfit connections, pipe etc?
thanks
thanks
