Discuss Please help, loud clanking noise from heat exchanger/boiler? in the Central Heating Forum area at PlumbersForums.net
Sounds like a circulation issue/ is there water in the system pic of the boiler ?
Eg overheat
To me, the noise sounds like an issue I've come across on a late 1980s boiler. Boiler was kettling slightly and the resultant gasses would block the flow pipe when the system came on. This was due to poor pipework run design that did not self-vent. The boiler would then bang when it tried to fire, the pump could not shift the air/steam lock, and the boiler would then overheat and would turn its pilot light out as a safety response. Ultimately the problem was handled by fitting an air separator to treat the symptom.
The owner had previously just turned the heating off for a bit when it did it, but said it didn't do it very often.
Turns out the problem was in the pump! British Gas guy replaced it and now it’s working fine. Thank you all for your responses though
Reply to Please help, loud clanking noise from heat exchanger/boiler? in the Central Heating Forum area at PlumbersForums.net
Hello The heating side of my Ariston Combi A23 has stopped working since a new 3 way valve has been installed. It's been a hugely reliable boiler...
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
T
Hello, I have just moved in to a new flat this week and have a problem with noise coming from somewhere around the top of the boiler. It's a loud...
Hi all, Got a strange grating noise when the mains water is running in a property I'm looking after. It's a ground floor flat, with a first floor...
Hi I'm dealing with Vaillant Ecotec 824 R1 in one flat. The boiler make a very loud noise when central heating is on - this is random and occurs...
