Please help, loud clanking noise from heat exchanger/boiler?
View the thread, titled "Please help, loud clanking noise from heat exchanger/boiler?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Sounds like a circulation issue/ is there water in the system pic of the boiler ?
Eg overheat
To me, the noise sounds like an issue I've come across on a late 1980s boiler. Boiler was kettling slightly and the resultant gasses would block the flow pipe when the system came on. This was due to poor pipework run design that did not self-vent. The boiler would then bang when it tried to fire, the pump could not shift the air/steam lock, and the boiler would then overheat and would turn its pilot light out as a safety response. Ultimately the problem was handled by fitting an air separator to treat the symptom.
The owner had previously just turned the heating off for a bit when it did it, but said it didn't do it very often.
Turns out the problem was in the pump! British Gas guy replaced it and now it’s working fine. Thank you all for your responses though
Reply to the thread, titled "Please help, loud clanking noise from heat exchanger/boiler?" which is posted in Boiler Advice Forum on Plumbers Forums.
hsadat,
hsadat,
