Discuss Please help me understand my airing cupboard! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
klaise
Good afternoon all
Would anyone be able to help a novice (me!) identify what all the plumbing in my airing cupboard is doing?!
I have a fair idea and have edited the photos below to try and help me understand.
A - Cold water feed to the water tank in the loft - 15mm
B - Vent for hot water - 22mm
C - Vent for heating - 22mm
D - Cold water feed to the central heating tank in the loft - 15mm
E - Help? Direction and purpose?
F - Help? Direction and purpose?
G - Help? Direction and purpose?
H - Help? Direction and purpose?
On the left hand side (out of shot) there is the 22mm pipe coming from the bottom of the hot water tank in the loft. This disappears behind this tank in the cupboard, where does this go?
Thanks for any help in advance!
E - cylinder flow
F - heating flow
G - boiler flow
H - cylinder return
And the 22mm pipe would more than likely be a cold to your bathroom.
Amendment to "D"
D - Cold water feed FROM the central heating tank in the loft FOR THE HEATING- 15mm
Also
"On the left hand side (out of shot) there is the 22mm pipe coming from the bottom of the hot water tank in the loft. This disappears behind this tank in the cupboard, where does this go?"
Cold feed to Hot Water cylinder, may have a gate valve on it in the cupboard to isolate Hot water.
Thanks to you both.
Snowhead: Yes my mistake, thanks.
AWD: Would you mind explaining directional flow?
Many thanks
E is coming from the boiler through the pump and 3 port valve into the cylinder coil.
F is going into the heating circuit (radiators)
G is the flow from the boiler going to the cylinder coil
H is returning back to the boiler to be reheated
Forget this post , as snowhead said it would be feed to cylinder was having a moment and forgetting it's handy to be able to fill a cylinder lol
Ah ok. So..
...the boiler heats the water and it travels through G, through the pump and diverted to the right through F for central heating. If there is too much heated water it is vented through C into a separate expansion in the loft.
...the boiler heats the water and it travels through G, through the pump and diverted to the left through E and into the tank which houses a cylinder coil. This coil heats the water in the tank and returns out of H to the boiler to recycle. The water in the tank is fed from the loft expansion tank, this is heated by the coil and is the draw through the top of the tank, through E and down into the bathroom.
This is the pipework coming into the bathroom under the bath.
There is 2 large pipe that just go along the width of the room and down, these must be to and from the boiler - G or H.
F leads to a radiator and through the rest of the circuit
E is the hot water tap and the cold mains.
Right here we go...
Hot water from the boiler flows through (G). Before it goes through the pump it is met by the heating open vent (c) and the cold feed to the heating system (d). It then travels through the pump and the 3 port valve. Depending on whats required by the cylinder thermostat or the customer heating controls it will either divert to the cylinder coil to heat the hot water stored (e) or to the heating (f). It can also do both if required. Then returns to the boiler to be reheated also picking up the return from the heating circuit (h). The hot water cylinder is fed by the large storage cistern in your loft through the pipe at the back. It is then heated by convection by the coil inside and comes out the top of the cylinder (b) the same pipe also goes into the loft space to the open vent over the large cold water storage cistern.
Congratulations to all responders. nice to see people being helpful, without taking the P or telling OP to call a plumber.
Reply to Please help me understand my airing cupboard! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any...
Hello, I've just found this forum and wondering if anyone can please help us. We've not long moved into our new home. It's has Johnson and Starley...
Hi I recently did some pipe insulating in my loft. The only two I didn't do were the vent pipes. Not sure if that is the right term for them...
Hi. Please can anyone help. My mum has just sent me this video of her airing cupboard. She had put the imersion heater on to warm the water for a...
1K
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering...
