Discuss Please identify divertor valve in the Water Underfloor Heating Advice area at PlumbersForums.net
Can anybody identify the make of this divertor valve. Actuator is missing!!
Cheers.
Could be a drayton TA M4 valve body
Thanks. I thought it might be a Drayton as there is a Drayton RB1 relay unit nearby.
I'll make some inquiries along the TA M4 route.
Apparently, the original failed, was replaced, and that failed?? The replacement was sent back to wherever, and didn't turn up. Neither did the original plumber...
Valve does do a 360 without restriction, so no jamming there.
Cheers.
Reply to Please identify divertor valve in the Water Underfloor Heating Advice area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
